little_fellow
- Joined
- Oct 6, 2009
- Messages
- 205
I've got power from the fuse wire to the module and I've got power from the bics controller to the module. I then used the ohm meter to probe for power going to the sticks and to the coils. My ohm meter starts off at 1.0 ohm with nothing hooked up to it and when I connect it, I get 0.575 ohm between the module and the hand control. I do get readings but I think this is like Tazza said earlier that the wiring itself would create resistance. I'm saying this because I get the same reading on the ohm meter with the power on as I do with the power off.I'd also check power to the connectors at the module, if that is there, move on to the wires to the coils and switches on the sticks.
For the sticks and coils, i'd use the meter to check for resistance. As there will be little to no power at these points, resistance is what you want to check. I'd remove the connector and probe from connector to connector and see if the wires are all good.
It's a shame i'm so far away, i have a 763 with a controller that i need to get to work on, but it's not going to happen just yet. If you can find someone that would let you test controllers, that would be a real help.
