shankatank58
- Joined
- Dec 14, 2013
- Messages
- 54
I would agree going electronic is the way to go today. But just to get it going the resistor is not required. It's purpose is to save the points. It would be bypassed to give full voltage to the points when starting then go through the resistor when running to make the points last. Many, many years ago I had a '55 Chevy truck with a 235 in it. To this day, the sweetest running engine I've ever owned.......unless I put a resistor on it. Then it wouldn't start. I got to where I could change the points on the side of the road in total darkness. By the time I figured out my mistake (no bypass) I had learned to keep spare points in the glovebox. Points were less than $2 at the time. Probably 10 times that today. If you decide to keep the current ignition system and need a new resistor; Mopars used that style resistor.Im assuming the wires were spliced together and bypassed that resistor??? Is that good or bad and can one be replaced if bad?
