Bandit1047
- Joined
- Jan 13, 2008
- Messages
- 117
Whenever I see a truck or a backhoe idling for hours at a time, it drives me nuts. (My wife says it's no drive, just a short putt!) When you ask people why they are idling their equipment, you get the most outrages answers; "diesels don't start when they are hot", "It hurts the engine starting it". These are just two of many answers I get when I ask the question. Neither of these is true, in fact all four major American engine manufacturers discourage engine idling. Cummins told me that engines that are subjected to long periods of idling need approximatly 30% more maintenance. Diesel engines need RPM or load to run at correct operating temperatures. On some equipment you can watch the temp. gauge drop as the engine sits idling. Cool diesels do not burn all the fuel that is injected into the cylinders, this causes carbon deposits on the valves and pistons and fuel to leak past the piston rings and as it runs down the cylinder walls takes the carbon with it glazing the cylinder walls. This carbon makes your oil gritty (black) and the sulfer in the fuel mixes with any condensation turning it into sulfuric acid. Non of this is good for the engine. The carbon build up on the valves and pistons reduces your fuel efficency. An idling diesel engine can burn 1/2 to just over a gallon of fuel per hour, and if your injectors are bad, it can reach 2 gallons an hour. At a cost of over $4.00 per gallon, who in their right mind still idles their diesel?
