My 743 is leaking hyd fluid and based on the buildup of oil/dirt I am 99.9% sure it is coming from the pump input shaft seal. My eyeballs dont bend around corners so I am getting ready to pull the engine to do a full cleanup in the engine area and grease the u-joint (looks like about a 1 hour job to pull the engine so not a big deal). QUESTION: once the engine is out can I change the pump shaft seal without removing the pump? The added work and drooling mess to remove the pump is not something I look forward to. Pump is a Vickers TA1919V10R. Any special instructions to change the seal? Thanks
