I know no one is accusing me anything and all of the ribbing is in good natured. I can take it but like to dish it out more! My unit is a 1992 and I am thinking the same thing you.....this reservoir would be huge and I would remember seeing it. Without being right at the unit to look I can go on the memory for now and I honestly don't believe that it is there. This unit was top of the line in 92 when it was purchased. I am the 2nd owner and the 1st owner was my neighbor who ran it on a diary farm. There is a screen/filter that is located in the cab by the foot controls on the right side of the unit....opposite the dipstick side. (left side if the bucket is at your feet) I am going to hook some gauges up to the pump tonight or tomorrow and see what I have. I am pretty sure the problme is somewhere within the pump. This unit has three pumps....a gear pump, RH pump, and LH pump. The LH pump is the one in question and is towards the rear. There should be a relief valve in the pump that may have failed but I think if it did fail then I would not have enough system pressure to raise the boom. The light comes on but I can still raise it. So the next thing that I think is the coupler between the pump and the motor. If the splines have worn off then it would work but would still have enough pressure to raise the boom? And on occasion a spline would catch which would account for the sudden propulsion that I can occosaionally get. This is my latest theory anyway. One thing I have learned is that with me whatever can go wrong will go wrong and I can never have the simple things to fix. Seems like all of my stuff breaks the most unusual way and never the same way twice. Thanks for tryng to help and I do really really appreciate it!This is an older 555 not a 565 so I guess it must be the chain case, it would be hard to miss a reservoir, they are among the largest components on the loader. No one is trying to acuse you of anything, but the last machine I seen without a hyd resercvoir was a 371 bobcat, they were a clutch drive and the hydrauic pump used the chaincase reservoir. Last made in 1977.
If they are using chain case oil, there must be a screen or inlet filter to keep chain and sprocket wear out of the hydro system. You should find where the sender is for the charge pressure warning light and install a 150 psi guage in there. or T it in. The charge pressure light should be off. If its on it would be good to check the actual pressure. No idea on the spec but 100 psi or so...
It is my understanding at times the wheels will not turn at all, does the motor lug down like it is working when this occures or does it just sound normal? It not a bad bearing or something that is binding up? Because the motor would labor in that situation. Will the machine turn the wheels if its up on blocks?.
Do you have anything else there with a hydraulic pump you could hook hoses to the wheel motor and put some pressurre to it to see if it will turn the wheels on the trouble side?
Any competant hydraulic repair shop should have a flow meter the could plump into you hydrostat for the bad side and see what flow and pressure the hydrostat is capable of.
Or could you make so hoses up to flip the motors to the opposite side of the hydrostatic pump without actuall removing the motors?
You need to find a way to narrow down where the problem is.
Also don't rule out asking independant equipment repair shops, locally they are my best bet, for my white equipment anyway. I have never been to my good Bobcat dealer, but they do provide great service on the phone and fax info when needed. So check around until you find one like that.
