Morning! New to site and 1st post! I own a 2001 Case 1840 and I recently bought it used. It has started up no problem for the 3 weeks that I have owned it. Never been running longer that 20 minutes. Load on trailer--take to site to use for snow----attempt to unload from trailer and then I have my problem. I stopped along the route to fill up with diesel. When I put the key into ignition and and turned it to the right, for a split second all of the dots/bars light up as to show that my gas tank was filled. As soon as I turned the ignition key more to the right to actually start the machine, I had nothing. NO lights on the control panel, no turning over sound, no clicking as I might of had a bad battery (which I can't imagine that this is the problem-it started just 40 minutes before in -32F degree weather with absolutely no issue). I don't have a manual, just a parts manual. Any idea as to where I should attempt to look for a problem. My initial guess would be a bad ignition switch or a fuse or fuses went. I just need some help. Any suggestions would be fantastic. Thanks! VInny
