Hi Guys,
I hope someone can offer me a fix for my 2002 Bobcat 753g (triangle head lights). When the machine is at idle all is good but soon after I give it some throttle, the oil pressure light comes on. If I continue at a higher throttle, the engine will shutdown in a protection mode but will fire right back up and then we are living in groundhog day all over again..... If I drop back to idle, the light goes off. I have replaced the sensor and no change. I put an oil gauge on it and have 60 psi at idle and 65+ at a higher RPM, so I know the oil pump is good. I suspect it is the controller. Here is the thing, everyone says the controller is in footwell on left side or behind a panel. I do NOT have anything in the footwell and NO panel. So it must be under the cab, right??? Follow the harnesses. Can anyone point me to a place to purchase a new controller? Does it need programming? Is this a Bobcat only part?
Thanks for any help in advance!
