Low oil pressure warning
JeffGascon
I have a Bobcat 863. After running a short time, the oil pressure warning light and alarm come on. I've replace the sensor, checked pressure with a mechanical gauge. The sensor has 8 volt supply and a good ground. the voltage output from sensor is .7 volts with engine off. The output with it running is 1.8 volts. Oil pressure on mechanical gauge read 46 PSI at idle. The display for service codes say none when I checked it. Where do I go from here?
