So it looks like replacement is the best option. What I'll do, when the snow season ends, is cut the heads off and push the pins. When I do this, does the bolt have to be cut flush with the pin or is there ample room in the bobtach to receive the pin and a short length of the bolt? Also, if the holes do need to be reamed where can I get the tool to do so? What I did for a temporary solution, and to prevent further wear, was cut a slot in a washer that was a tight fit behind the head of the bolt and used a hammer and punch to put into place. This tightened everything up so there is no movement. I tried an impact gun after installing the washers but still no luck. The taper will only hold about 40 lb/ft. I'll try again next time I have a load in the bucket. I only use the machine about 10 hours a year, and its light duty work, so I'm not terribly concerned about worsening anything before I take it apart. Thanks again for everyone's help. George.
