T250 Bucket curl is drifting
magnm01
I have a T250 that will not hold the bucket level. The heavier the weight the faster it droops. This makes using a brush hog impossible. How can I determine if this is an internally leaking cylinder or a solenoid? I really need to get this fixed. I
First guess would be a bad tilt cylinder piston seal. If the tilt creeps down fast when the machine is turned off, then it is most likely the seal.
