ls565 electrical starting
sdr08022
ive got a used machine i bought 6 months ago recently it wont run in run mode it runs in service mode but sometimes blows the ignition fuse . i got a f03 error a couple of times the engine preheat light does not time or go out any more the battery light stays on on and reads 0 but the battery is over 13 just looked over grounds and areas for rub spots but i didnt see anything backed it out of the shop and fuse blew again any ideas? scott
The Fo3 code is your preheat. on my 865 it is a single unit mounted on your intake. if its like mine it is easy to access and not expensive. it could be shorted out. Its just a spring that heats up. Mike
i dont see it listed on messicks parts list only shows the relay
Its not a relay. your glow plug may be different on your 565. on my 865 its on my intake manafold. You could have only one as I have or you could have one for each cylinder. Look on your intake manafold and on the head for your glow plug/s. there will be a single wire rinning to each. Il look on messick later. Short on time. If you can post the engine you have maybe someone else can guide you better. Mike
I misunderstood your post. about the relay. Undertand they only show the relay.On messicks look on the head and intake manafold for glow plug ,they may call it something like preheat ? Mike
