well thats good to know. i am hoping for the best, after talking with a few people, ill keep you posted.
It always sucks when something dies before its time, especially our beloved Kubotas.
B4 you pull the engine I'd remove the plastic cover off the flywheel and remove the main drive belt that runs all the pumps. Also lift the cab remove the v belt for the engine cooling blower. Turn the pulleys by hand and see if anything feels rough, like a bearing is piling up in the pumps or blower fan gear box. If those appear normal, I'd drain the engine oil and look for debris.
If the oil looks normal, refill it with new oil and fire it up. Now your only listening to the engine, no pumps or blower noise. If you machine is a G series or has the older Boss gauge package the hydraulic warning light will go off because removing the drive belt eliminate the hydraulic charge pressure the computers is expecting to see.
You may well know exactly where the problems lies, but I'd rule out these other areas first.
If there is such a thing as a positive note, These Kubota's are among the cheapest to rebuild, remans are @ 3200 and a new one can be had outright for @ 4k if your core is shot. With 1500 hours it should not be completely wore out and you may be able to just fix the problem area, depending on what the failure is.
