742b engine locking up
rustywalrus41
I have a 742b with the Mitsubishi engine. Waiting to receive manual but in the meantime wanted to ask the forum for help. Engine spins about 180 degrees before a loud clunk is heard and it locks up. Is there access for the couple by lifting the cab or does engine need to be pulled
laurencen
do you have a borescope you can feed it at the back of motor to look at the coupler and see if the fan is turning?
Dave J
There are only 2 nuts in the cab that need to be removed to tip it. They should be 3/4", then you can see the coupler and watch how it moves. If you have not greased it recently it would be a good time to do it especially the slide on the spline.
reaperman
The U-joint between the engine and hydro pump may be broken. You dont want the machine to start without knowing for sure if it's the U-joint or not. If it does happen to start with a bad U-joint, bad things can happen fast.
R
rustywalrus41
Thank you sir waiting for towing company to bring the unit to my house to begin looking at it. Gonna try to sneak in the camera and take a look
reaperman
If the u-joint isnt broken, grease it while you're already dirty. Its not easy, but its often forgotten since its such a pain to access
reaperman
A broken coupler is just a suggestion. Given the age of the machine and being its not easy to maintain, plus many owners arent aware the u-joint is even there.
R
rustywalrus41
Coupler looks fine removed plugs and with the scope I can see the problem is in #1 cyl. I will make time this week in the afternoons to start pulling the engine. After scraping all the grease and dirt looks like its just the 1/2 nuts holding the plate and just moving hoses and wires out of the way.
