843 bobcat locked up
John23
Left side front and rear axles locked up.
Pulled drive motor,no difference
I'm going to pull inspection covers for chaincase.
Do I have to remove pumps to look?.or just use front cover.
Can front pumps be split to give e me more room?
Looking for suggestions
i think pulling chain covers would be my next move, to see if there is a chain failure or a bearing issue.
What did you end up finding out? Also did you remove the two pumps or just the front one? I need to work on the parking break as it leaks from the handle fluid according to the manual there’s an o ring but it shows as you need to the remove both panels to replace it
