bobcat 310 skidsteer
Justin
I am having some problems with my 310 skidsteer. It works fine for a while then all of a sudden the clutch on the engine gives while trying to turn or move the bobcat in low range and i have to wait till it kicks back in. I can use high range and it works but i also noticed high range doing the same thing. Could the relay be causing this problem? Seems to do it when it is all warmed up completely. was working great till i shut it off and turned it back on and then it quit on me again. if i let it sit overnight and go back in the morning it will work like it should.
Have you checked your oil level? The cluttches could be out of adjustment too.
There are a few experts in here with m610s and i would guess the 310 is close to being the same basic setup with the clutches.
J
Justin
well, i thought the same thing, but i watched and the clutch stops the belt from spinning when it happens so it is not in the undercarriage of the machine. I thought it was the clutch at first, but it seems like it is something electrical to me. I could be wrong, would not be the first time..lol
