310 stalls when turning
rph_77
I recently bought a 310 that wasn't running. I knew it wasn't running before the seller delivered it, but I hadn't seen it in person. After looking over the mess the original owner had made of the wiring harness, I decided it would be easier to do a repower. So, it's got a brand new 15hp motor from Princess Auto; I don't think that's the source of my problem. Everything seems fine when driving around, hydraulics operate more or less as they should, but if I try a zero turn, it stalls. The drive belt is a bit loose, as I haven't yet adapted the tensioner off the original motor, but I'm going on the assumption that if there's enough grip to stall the motor, that's not the problem.
Suggestions?
i know nothing about that machine but I would tend to believe that you are correct. Could it be there is not enough torque in the engine or run to slow of rpm or the governor is not set right . guessing
