between cat and case
marc21
i've narrowed my decision between cat 246 and case 90 xt or case 4??. I'm swaying towards cat because of there easy of use, maintenance and there operator comfort.
sterlclan
never run a case skid steer but there full size loaders s$#@ Cat sounds good to me....Just my 2c Jeff
bobcat_ron
My choice would be CAT, I've "tried" to get into a cab from a new Case, and almost popped my man cherry due to one of those pesky long joy sticks being so long. When U did finally get into the seat, the "tunnel vision" was so bad I felt closed in and claustrophobia set in. CAT has a huge cab compared to Case and the reale value is better.
M
marc21
thanx for your input guys, anyone else have a an opinion?
I have never had the oportunity to sit in a cat but the fellow who sold me my backhoe had one (early one) and complained that it could not be driven in a straight line. Not sure if it was a issue with the first ones out or his particular loader. I'm sure if it was a issue cat would have it adressed by now.
As for the Case I've only had very limited experience with old 1840 and 1845.
Over at lawnsite.com there are some die hard case boys from the new generation though.
lgammon
there is an adjustment for the steering on the cat just ask the dealer he can set it up for you
M
marc21
ya, there alot better then the older ones but there stil a little weird. They kinda hang into the middle of the cab till u put bar down, then they sit nicely.
M
marc21
so what size skid steers compare to the 246, in size and lift capacity? would it be like a 75xt and case 430?
They are one hp apart 74 vs 74 case is 2000lb roc cat is 2150lb roc.
Case brochure from www.casece.com
http://casece.com/files/tbl_s93PDFRepository/PDF521/717/Skid Steer 400 Series Family.pdf
Cat specs www.cat.com
http://cmms.cat.com/cmms/servlet/ca...&specTab=y&subfamilyheader=Skid+Steer+Loaders
246C Skid Steer Loader
--- Select a Model --- -----Skid Steer Loader----- 216B Series 2 216B 226B Series 2 226B 236B 232B 232B Series 2 236B Series 2 242B 246B 248B 242B Series 2 246C 256C 252B Series 2 252B 268B 262B 262C 272C​
Specifications
Engine
Units: US | Metric
Engine Model
Cat 3044C DIT​
Net Flywheel Power
73 hp​
Gross Power
75 hp​
Gross Power SAE J1995
75 hp​
Engine Power ISO 14396
74 hp​
Net Power EEC 80/1269
74 hp​
Net Power EEC ISO 9249
74 hp​
Net Power SAE 1349
73 hp​
Displacement
201 in3​
Stroke
4.7 in​
Bore
3.7 in​
Operating Specifications
Rated Operating Capacity
2150 lb​
Rated Operating Capacity w/Optional Counterweight
2423 lb​
Tipping Load
4300 lb​
Breakout Force, Tilt Cylinder
7328 lb​
Weights
Operating Weight
7381 lb​
Wheelbase
48.8 in​
Length w/Bucket on Ground
145.3 in​
Length w/o Bucket
123 in​
Height to Top of Cab
82 in​
Vehicle Width over Tires
66 in​
Max Overall Height
157.4 in​
Bucket Pin Height at Max Lift
122.9 in​
Bucket Pin Height at Carry Pos.
7.8 in​
Reach at Max Lift and Dump
23.6 in​
Clearance at Max Lift and Dump
95.4 in​
Ground Clearance
8.8 in​
Departure Angle
26.4°​
Bumper Overhang - Rear Axle
42.8 in​
Maximum Dump Angle
40°​
Turn Radius from Ctr - Rear
58.5 in​
Turn Radius from Ctr - Coupler
64.1 in​
Turn Radius from Ctr - Bucket
94.9 in​
Max. Reach w/Arms-Parallel
54.6 in​
Rack Back Angle at Max Height
96°​
Hydraulic System
Hydraulic Flow
Standard​
Hydraulic Flow
High Flow XPS​
Loader Hydraulic Pressure
3335 psi​
Max. Loader Hydraulic Pressure
4061 psi​
Loader Hydraulic Flow
22 gal/min​
Max. Loader Hydraulic Flow
33 gal/min​
Hydraulic Power
42.8 hp​
Cab
ROPS
SAE J1040 MAY94, ISO 3471:1994​
FOPS
SAE J1043 SEPT87, ISO 3449:1992 Level I​
FOPS Level II
SAE J231 JAN81, ISO 3449:1992 Level II​
Power Train
Travel Speed Forward
7.7 mph​
Travel Speed Reverse
7.7 mph​
Travel Speed Forward - 2-Speed Option
11.9 mph​
Travel Speed Reverse - 2-Speed Option
11.9 mph​
Service Refill Capacities
Chain box, each side
2.6 gal​
Cooling System
3.7 gal​
Engine Crankcase
2.6 gal​
Fuel Tank
26 gal​
Hydraulic System
15 gal​
Hydraulic Tank
11 gal​
I'd love to ordering either.
kelly_b
I have always personally been a CAT fan as my dad was a heavy-duty mechanic for them.
Cam2
I have an 04 Cat 246 and I also just bought a Case 90xt. The case has about 4000 hours on it and was worked hard and very loose, but I still like it. Has a ton of power and although the controls are different, each has it's own qualities. The Case spins much better in tight spots. Doesn't matter much to me....I'll use either, but usually go with the Cat, only because I'm more used to it than the case. Paid 3000.00 for the Case, couldn't pass it up.
