What's your favorite make and model of skid steer?
bauertree
Looking to step into a 70 or 80hp skid steer from a 763.
What's your personal favorite make and model and a little explanation why?
I've always run Bobcat. Prefer older models so I can work on them. Trying to stay away from common rail fuel injection.
Love Kubota engines and hate the Cat 2.2.
Thanks
Without question the old Case 1835B. They are everything a skid steer should be, just too small.
Cat 2.2 is probably a “Perkapillar”.
Thanks
Back in the '80's, I bought a new HydraMac 20C with their 10ft backhoe attachment. It was my favorite, and equivalent to the Bobcat 800 series. I previously had the 700 series Bobcat, the one you had to block it up to get to the oil drain and filter.
I liked the HMI because it was easy to work on, the filters were all located at the rear of the machine. The radiator was attached to the rear door so you had full access to the engine. And, the engine/pump was on a large plate held in by two bolts. Take those 2 bolts out and the engine/pumps could be slid back and removed as a unit. The pump and drive motors were Vickers and rock solid.
The engine was a 4 cylinder Isuzu marine with about 60hp if I remember. Only issue I had in the 3,500 hrs was I had to change the glow plugs.
The final drive was gears, as opposed to chain drives as on most skid steers. No adjustments needed, just oil change.
And I really liked the backhoe attachment because it was attached to the arms only; not to the body. You pushed down on the lift arm control and locked it down via hydraulic; opposite of float mode. If need by, I could raise the lift arm to raise the hoe attachment to get over obstacles. Also, the hoe attachment hydraulic controls were on a "tilt forward/backward" pivot so you sat in the regular cab seat, not the standard additional seat on the hoe attachment. That allowed the operator to move the skid steer and operate the hoe attachment from one seat. The disadvantage was visibility of the trench being dug was obscured, but not by much.
And, that skid steer was one of the few that had the "tee handles" for steering/drive. The entire machine was thought out to be tough, easy to work on, and strong. That was my favorite. My current Gehl 4835DXT is good, but not the same. I sold that HMI because I needed a smaller machine and HMI went bankrupt. Otherwise, I would have bought their 16.
No prob. So what's your favorite 70hp machine?
I just don;'t have a FAV machine/model to list here!
I;m just happy if what I got is working right and doing want I need it to do!
I like my bobcats. The little 440B has been around here for ever it seems. Great to get into the bank barn to clean it out and doesn’t tear things up to bad when helping the wife with yard work
The S650 is a beast for whatever we need it to do where the tractors can’t get in and a LOT more stable then the little 440. It feeds the bale wrapper faster in tight quarters and gives the operator a better line of vision when doing jobs involving lifting around equipment.
My neighbour had a hydramac, and I loved it. Those t handles were so intuitive and smooth. The only problem he has was replacing the roll pin in the knuckles on them, that was the wear point.i have a 743 bobcat and it's the perfect size for what I do.
I’d say the New Holland 328 is my favorite machine right now,we’re running 2 right now and I’d like to find another used one with low hrs to replace the kubota we also have I think it’s a sv75
Yes, I lubed the knuckles with a liquid graphite used for locks that dried quickly, leaving graphite lube behind. Grease was hard to get in there, plus attracted dirt. Retrospect, probably should have drilled and tapped for grease zero.
