I installed the new spool and coil before I installed the PTO hoping that would be the only problem, but it still didn't operate and it was getting 7.5 volts???. I also picked up a new seat at BC, one of the mechanics had it in his work area and he let me have it for $50. Mine was rusted on the bottom. I also ask him if there was a way to bypass the seat sensor, he said it was wired into the computer in such a way he had not found a way to bypass. A couple of other questions.......... How do I drain the hyd fluid from the system, I want to replace with new fluid. Mine creeps to the left a little, is this just adjustment to the controls?. The manual doesn't explain the 'bucket position valve', does this keep the bucket level?. ThanksThe "pto" button just activates the coil we have been dicussing. Your seat bar switch still needs to function but not the switch on the seat. I still find it a pain to push the button after I have pulled down the seat bar. But it is reliable. My 553 has not had the update to the pto button but my 853 has. After initially getting the seat and seat bar switches set correctly I have no problem with either. The 553 is a little nicer because the seat bar comes down and your ready to roll. I still find myself trying to take off in the 853 b4 hitting the button. (habit from the 553)
Should put up some pics of the seat and safety bar switches. Activating the switch is just a matter of moving a small magnet into close (proper) promimity to the other side(sensor part) of the switch. With the seat one often a small rock , pop can prevented movement or operator that was to small to compress the seat mounting down, So after numerous complaints Bobcat finally came out with a pto button that replaced the seat switch to solve the problem.
Glad to hear your running with a farely minor repair
