pivot bracket is the correct wording I guess....between the motor and bobtach to keep the auger plum..BC dealer wants $409 for it and $50 for the two pins.....ThanksI made a root bucket used 3/8 plate and the swivel like a swivel socket?there are pics of the bucket in the media section...Jeff
I just went and purchase some 2 X 2 thich wall square tube and drill a hole at each end. When you drill the first end turn the tube to the next side for the other end. Pretty simplepivot bracket is the correct wording I guess....between the motor and bobtach to keep the auger plum..BC dealer wants $409 for it and $50 for the two pins.....Thanks
Thanks farmboy, I didn't think 2x2 would hold up but I will take your word for it. SteveI just went and purchase some 2 X 2 thich wall square tube and drill a hole at each end. When you drill the first end turn the tube to the next side for the other end. Pretty simple
I've only use a small 6” auger, you could use a solid peice of square stock to make it stronger.Thanks farmboy, I didn't think 2x2 would hold up but I will take your word for it. Steve
