250 skidsteer, Hiflow info
vettes
Is there any way to tell visually if a machine is aux hiflow or not? (if no sticker is present by the aux lines that is.) Thanks Andy
If it is a high flow there will be a second hydraulic pump driven off the cam geartrain of the engine. It is mounted just above the oil filter (on the operators left rear side of the engines) by the look of the pictures in the manual. The main (low flow) hydraulic pump will drive off the end of the hydrastats as is common on most skidsteers.
