Skid Steer front tires go low
BigMac
I bought used skid steer and it seems both front times loose pressure over time. I've had it about 2 wks and both front tires had like 10 lbs in them yesterday. Shoudl I lift the front tires off the ground, using the bucket? Take the lug nuts off and take them to a local tire dealer?
It sounds like you need tubes. I have a machine that i fitted new tyres on, in 5 or so years, i have needed to pump them up once or twice.
Slow leaks are usually dirt related, dirt in the valve stem if the caps are missing, but most likly dirt between the tire and rim. It could also be a slow leak in the valve stem if something was hit or even a really small hole that leaks slowly. Anyone who works with tires should be able to fix it. I however would suggest using jacks to lift the machine. Using the bucket that way can kill someone.
Its up to you but I'd use a jack to lift as the machine is new to you the hydraulics may not be something to trust. Then inflate the tires to the pressure on the sidewall and squirt soapy water over them. About a tbsp to a quart should do it. The leaks will show as bubbles and when you take them in you will know what to expect.
tubes and skidsteers don mix.. break em down clen rims(wire wheeel) if bent heat and beat. cheap tires are like cheap toliets, i have found no aftermarkets that hold up like a bobcat heavy wall 10.16.5 and sealant, seen em all,to kick it up a noych the severe duty mich.. sevral of my cocrete guys swear by them. and they have done the math cost per hr.,
Ok, thanks for the recommendations. I will use a a jack and will have the tire guys try and fix them w/o using tubes - if possible.
