I asked the forum guys for a section on repowering skidsteers since that was the reason I found this site, and I figured there were others out there like me who likely had a good skidsteer, but the engine wore out.
I see quite a few older ones out there yet, several being sold at auction, and the main sticking point seems to be ones with older engines. If you can fit a new one in, you might get several more years out of your machine.
It would be nice to see some guys who have changed theirs over and put diesel engines in. I've heard the Onan engines are popular.
Anyway, I figured I would start out with my own repower of my Case 1816 skidsteer.
At the start of last winter, after clearing three driveways of snow from the first snow fall, the engine made a noise and lost power. I managed to get it back to my shop, but I could hear a clanking coming from the engine. After thinking about it awhile, I figured I didn't have the time to take the engine out, figure out what kind it was, try find some parts somewhere and hope they would work, get it back together and running in time for the next snowfall. Having previously called salvage yards all over the country for a hydraulic pump, I figured I wouldn't have much luck. I then found out the engine was not original Tecumseh, but had been replaced at some point with a Wisconsin TJD. It had been repainted, so the dataplate was painted over and hard to tell what it was.
I did some searching again on the internet that night for repowering a skidloader (and found this site). Farmshow magazine ran several articles about repowering all kinds of equipment, including skidloaders, so I thought I might find something.
I found Smallenginewarehouse.com pretty quick and found they had a huge selection of skidloaders and other equipment listed with engines that would work in them, including one for my Case 1816. I ordered the 16hp Briggs engine.
The next night, I took out the old Wisconsin engine hoping the snow would stay away for a few days. I got the new engine in three days, took it out and started looking at what I needed to do to get it installed. The engine fit into the space perfectly, but the shaft would sit lower than the Wisconsin did. It also had no chance of matching up to the existing mounting bolt holes. Another problem that came up was the existing pulley off the old engine was a larger shaft size, and had a tapered hole which shims fit in to hold onto the shaft.
I took some measurements, then decided I could weld some plates and brackets together to make a short stand for the engine to mount on. It fixed two problems, raising the shaft high enough, and I could drill proper mounting holes for the engine.
For the pulley, I bought a shaft collar of the right size and decided to weld it on the pulley. Risky, but I didn't have much to lose.
Once I got the mount welded together, it was a matter of bolting things together, running the existing wiring, throttle and choke cables and gas line, and firing it up. Even the old belts still worked.
It started and ran great, and seemed to have plenty of power considering I was replacing a 18hp 2 cylinder Wisconsin with a 16hp 2 cylinder Briggs.
Now I wanted it to snow to try out the new engine, and a couple nights later, I got what I wanted.
I fired up the skidloader, cleared all the driveways and got it back to the shop when I heard some more clanking. The weld on the shaft collar had broken from the pulley.
The new engine was easier to work with than the old one. The motor mounting bolts were easier to get to, so after removing them and loosening the belt tension, I could slide the motor back and remove the pulley and collar. I then found out the pulley was actually cast iron instead of steel. Again, Farmshow came through since I had just read an article about welding cast metal.
To weld it, several guys suggested the cast piece had to be heated up pretty good, and short welds using nickel rod had to be used. Reheating in between short welds would help, then it had to be cooled very slowly.
After heating it up good, I welded it with nickel rod, reheating often, then when done welding, kept reheating it less and less until it cooled enough.
I put the pulley back on, tightened the belt tension and bolted the motor back down, and it lasted the rest of the winter, which was great because it was a record snowfall for our area last year.
It's been holding since, the engine has been running great, and it uses much less gas than the old one did.
Actual time from breakdown to getting the new engine in and running was about 10 days, and cost was roughly $1100.00 by the time I was done.
Speaking of older machines, if you guys know of good salvage yards anywhere in the country, go over to the Salvage section and post a link. Help us guys keep our older machines running.
Thanks
Thanks
