on going repowering a 610
sundown57
i picked up what i think is a 610 a while ago. it was pretty well stripped. so here is what i did. I repowered it with a 4 cylinder water cooled Kohler L654 from a generator. but i haven't found a way to put a hydraulic pump on the motor yet. plus all the hydraulics were missing from the machine like the pump, all lines. all valves, levers, rods, even the peddles were missing . so i bought 2 electric/hydraulic power units and mounted them on the back. works amazingly well. any way to post pictures of it in here ?
6brnorma
Yes there is a way to do it…….I'm not the one to walk you through it however as I've never figured it out myself. I do, however, encourage you to do it as I'd love to see the repower.
S
sundown57
id love to show it off. lol I've done a ton of work to it .
S
sundown57
Here is a link to a picture posting tutorial:
http://www.skidsteerforum.com/DesktopDefault.aspx?tabid=54&frmView=ShowPost&PostID=2445
Looking forward to seeing your results!!
Cheers - SR
cross your fingers . first time posting pics. thanks for the advise
http://i68.tinypic.com/6qgo7r.jpg
http://i67.tinypic.com/2wd3kvt.jpg
http://i64.tinypic.com/4rojo1.jpg
6brnorma
Wow…….that took some work…….not much room left in that compartment. What all do you have left to have it working 100%? How many HP does that engine produce.
S
sundown57
its 100% done now. I have been using it a lot lately. i actually have 2 of those electric/ hydraulic units on it with one working the lift arms up and down under power. the other one curls the bucket up and down , again power both ways . and i have one to close the variable speed which only needs power in one direction. BUT what want to do is see if i can take the governor off the engine and use a cable to set the throttle. then replace it with a hydraulic pump and try to get it back more to the way it was originally. but i need so many parts not sure that will ever happen . so it might just stay this way for a while . but for a yard machine it works well. Im not sure what pump might fit the motor , not sure if it would be big enough to drive the hydraulics .
SkidRoe
Well done!! I did a little edit in your post so the pictures show up directly.
Cheers - SR
6brnorma
thank you for that . the post looks a lot better when its done right.
Without a serial number, I can't really tell for sure but that machine did not come original with the Wisconsin engine. The cut out in the right side indicates that it was a M-611, M-610D or maybe a M-600D but it came with a diesel engine original. I'm a little skeptical that you could have squeezed that engine in the standard M-610 with the smaller cut out for the Wisconsin engine. You have some serious talent (or pure-D-crazy) to have made that work. Nice job.
S
sundown57
I've heard ( crazy ) a few times lately . maybe best to go wit that lol. I found a tag under the seat that says Model 610. But i do not see any letter after it and i do not see a serial number on it . would it be stamped on the machine some where ?
6brnorma
If you remove the right hand side (chain case) viewing panel. It will be stamped on the body between the two forward most studs…..upper row.
S
sundown57
i look for it next time i have reason to pull that cover. I just got it back on last weekend. I made a new pulley for the alternator and replaced both jack shaft bearings.
