Stone Hands
- Joined
- Sep 9, 2011
- Messages
- 35
Can someone suggest to me a course of action on this little problem. I have a lat model 863 turbo F series Bobcat. When I was changing the Hydro filter I accidently broke the end off a sending unit. This I am told is a Hydro temp sending unit. It screws into one of the filters. It has a brass piece with a small set screw attached to it and a two wire lead screws onto it. I replaced the unit, $24.00 from Bobcat so no biggie, but when I put it in and attached the lead to it the red light still stays on in the cab. It is the second light on the upper panel and has a gear and oil symbol on it. Any ideas if there is a reset, or code, or fuse or relay that needs to be checked. I did check the fuses in the back of the unit but did not find a bad one. Help would be greatly appreceiated.
