Don't be adding extra light on the same circuit as the other lights. If the breakers are still good and you reset them take the right side panel off and check out your light switch or wires you probably melted the terminals and you need to get a new connector and terminals. I see this a lot on Gehl skids. If you run extra lights you need to run them off of the battery with a fuse or relay with a separate switch. The factory wire harness can not handle the extra load with the lights.i checked my dash theres 2 white reset buttons but there pushed in and did not pop out! What do u think i should try next ?
are the new connectors and terminals found behind the pannel? were can this be found .Don't be adding extra light on the same circuit as the other lights. If the breakers are still good and you reset them take the right side panel off and check out your light switch or wires you probably melted the terminals and you need to get a new connector and terminals. I see this a lot on Gehl skids. If you run extra lights you need to run them off of the battery with a fuse or relay with a separate switch. The factory wire harness can not handle the extra load with the lights.
Your breakers maybe junk now. The connector is behind the panel it plugs onto the back of the light switch. Did you check for any burned wires?are the new connectors and terminals found behind the pannel? were can this be found .
i removed the switch this afternoon and the connectors were infact melted!!Your breakers maybe junk now. The connector is behind the panel it plugs onto the back of the light switch. Did you check for any burned wires?
