LX 865 will not turn over
UA_HoBo
865 will not turn over in run or service. Tested starter off machine. Heat relay clicks. I have a service manual and tried to jum run service switch, Switched out relays. Still no luck any help would be great.
Start at the battery. When the batteries short out they are done and you can't jump them to get the unit started. You could remove the battery cables and install bolts into the cables and jump to the bolts. Limited success with that procedure though. Most jumper cables can not handle starting the unit because of their length and gauge. If your battery checks out then clean your battery cables. top and bottom and battery post base. If you have a volt meter and a helper you can check for voltage drop across the battery and from the battery to the frame when attempting to start.
I have load tested the battery with a load tester and it shows good.
