I have a Lx 665 skidsteer. The right side forward lever skips, or loses power.
Leonard8888
I have a Lx 665 skidsteer that the right hand side forward and reverse lever is skipping.Only when moving forward?
could your sprockets on the chain case be loose or worn out? causing the chain to slip on sprockets?
should be a panel that you can open to view sprockets and or can jacks skid steer up on that side and check tension on things by checking slop in wheel movement
