Unlatch the seat and raise the seat so the rod locks in the slot. Look where the parking brake handle goes through the cab floor and you will see a lever and a spring link attached to that lever. There is a cross shaft which attaches to the spring link on the other side. The spring link is attached to a lever at the bottom which activates the parking brake by screwing, shaft is threaded, in against the brake puck. The lever at the bottom has one 1/4" bolt holding the lever on the shaft. Loosen the bolt about a round. The following instructions are from the service manual. The only change I would suggest is instead of removing the spring link from the bottom lever, I would remove the spring link from the top lever. You may need to give the lower arm a pry to free it on the shaft but it should come off fairly easily after that. Not a lot of room to work but not that difficult either.................
Parking brake in the disengaged position.
1. Unhook the lower pin of the spring assembly, 1,
from the control arm at 3.
2. Push the arm, 2, down to turn the shaft into the
caliper support to remove any play in caliper and
disc.
3. Loosen the setscrew in arm at 4, and slide arm
off the shaft.
4. Rotate the armup so the spring can be rehooked
and slide the arm on the corresponding shaft
splines.
5. Position the control arm on the shaft for clear-
ance between arm and other components when
the brake is engaged and disengaged.
6. Tighten the retaining screw in the control arm.
7. Connect the spring to the arm and install cotter
pin in spring link at 3.
NOTE: The parking brake control lever must be in the
lower (disengaged position) for parking brake adjust-
ment.
45
