That is an option too, remember to jack the lift arms up a little so you can get the rod out.I leave the casing pinned to the machine and only unscrew the gland nut and pull the rod out the case , you will have to lossen the hose going to the back side of the case to relieve the vaccumm that will occur when you try and pull out the rod , loosen that hose out away from the cylinder under the boom where the two hoses meet , a very large pier of channel locks work well to unscrew the gland nut if it isn't too tight and works well to finish off unscrewing it after a froozen one is broke loose
Im going to do it saturday tksThat is an option too, remember to jack the lift arms up a little so you can get the rod out.
Just one other thought to add. I had a lift cylinder crack at a weld joint on the bottom end (back end) of my 742B. It was an easy fix but couldn't see the crack until totally removing the cylinder from the machine. JohnIm going to do it saturday tks
Everything went fine with the cylinder reseal. tks.Just one other thought to add. I had a lift cylinder crack at a weld joint on the bottom end (back end) of my 742B. It was an easy fix but couldn't see the crack until totally removing the cylinder from the machine. John
Any details of how you did the job or ways that would have been better?Everything went fine with the cylinder reseal. tks.
don't use a screwdriver to install seal on pistonAny details of how you did the job or ways that would have been better?
Brian
http://www.mediafire.com/?fboumtcw3bhdon't use a screwdriver to install seal on piston
How did you fix this? Did you remove all the guts and reweld?Just one other thought to add. I had a lift cylinder crack at a weld joint on the bottom end (back end) of my 742B. It was an easy fix but couldn't see the crack until totally removing the cylinder from the machine. John
