Left lift arm hyd. hose replacement 853
perry
I think I may need to replace one of the left lift arm hyd. hoses, there is some slight drip?. On the other hand, it might be from over greasing. I cleaned the area with purple magic and operated trying to find the leak but nothing?.
Just in case, what steps are involved with replacing the hose.
farmboy55
No big deal, just make sure you use 2 wrenches. You can open the engine door and get to the other end of the line. take it down to the parts place and have a new one made.
P
perry
Not quite Farmboy, It's a mix of hard and rubber lines and the left tilt cylinder will probably need disconnecting. The hard lines look like they can loosened and bent down slightly?, just not sure. there are always little tricks people learn when working their machines, I'm just trying to find someond that's done this.
Thanks
