I only see one 17 mm nut that Is as far down as it wil go, and there is still a lot of play.That should be an easy one to do. If you pull the rubber boots up, you should see a nut that you can run down to where it makes contact again with the smaller valve tops. Then, snug it back down. That is a simple one.
Hmmm. If the nut is all the way down, then there is probably a lot of wear in the joy stick pivot area or it is time for rebuilding it.I only see one 17 mm nut that Is as far down as it wil go, and there is still a lot of play.
Replace u-joint.nut has nothing to do with adjusting slackHmmm. If the nut is all the way down, then there is probably a lot of wear in the joy stick pivot area or it is time for rebuilding it.
I don't see a u joint part on the parts page. Can you give me a little more info. Thanks.Replace u-joint.nut has nothing to do with adjusting slack
217-3850 u-joint kit drive side 289-8440 u-joint kit hyd controlI don't see a u joint part on the parts page. Can you give me a little more info. Thanks.
Thanks. I will check those out.217-3850 u-joint kit drive side 289-8440 u-joint kit hyd control
