I have a 2005 Cat 226 Skid steer with no pilot control function. Sticks are dead. Machine runs great, all the indicator lights on left console work, park indicator comes on and goes off when I engage but that's all it does. No hydraulic noises or clicks or nothing. Won't lift, tilt or go forward nor back. Possible additional information. The green wire that engages relay B in the engine compartment with the key on was not hot so I jumped off the green wire going to the A relay. That powered all the lights on the left console. Relay C is powering up properly. Relay D has power with key off but does not engage with key on. Additionally all the fuses are good and powering up with the key as they should. As to the relays on the fuse panel, 2 banks of 3 on each row, relay 1 is always powered, relays on thru 5 come on with the key, but relay 6, bottom left, never gets power. Machine has 6500 hours but appears to have been well-maintained, no leaks, and I have repaired some chaffed wires where critters have gnawed on but I don't see any other problems. HELP!
