I have a 1999 75XT that has been great and running great. However, the last time I used it, it died and wouldn't start. It didn't sputter or anything. It just suddenly died. At the dealership, they suggested checking the feed pump first. It wasn't getting enough pressure, so I put on a new feed pump. I pulled all the fuel lines and none are blocked. I also used the primer to bleed the air, but I can't get diesel to come out of the lines when I crack them at the injectors. However, I have plenty fuel coming out of the filters and to the injection pump. I was told it might be the fuel shut-off solenoid. Is that the same thing as the solenoid valve that is on the top of the injection pump (part number A77753)? If so, is there a way to test it before spending $93 on a new one? I appreciate any help. Thanks.
