Hey Mike10-Question on LX/LS Dash
mfyock
Mike, Got a question on a dash you might be able to help me with. I have a dash that is giving me problems. Its a "silver" dash, BUT when I yanked it out I noticed that the circuit board on the back doesnt fit properly. Only a couple of the holes line up. It is clearly a different board that someone put on this dash. Possibly a board off a gold dash? Are the gold dashes longer? I remember swapping dashes one time and the new dash wouldnt bolt into the steel housing. The entire hole was too small. I ended up pulling out the steel housing and cutting it larger. Is this what happens when you put a gold dash in a silver dash machine??
NH has a special gold trimmed panel which wii fit the opening on the older models. One way to tell which. Circuit board is installed on the faceplate is to look at light bulbs attached to the panel. If they are replacable then the board is a silver trimmed panel. The gold trimmed board have the bulbs hardwired to the board.
Thanks Mike! That helps me a lot!
