Hello All, I am having problems with a fairly high hour (4800hrs) LS140 skid loader w/ N843 engine. Engine start ok and runs, not much smoke of any kind but LOUD knocking noise. Hard to tell if it's top or bottom end of motor. Compression testing on 1 to 3 cylinders was 475, 250 and 325 - so 2 and 3 are low to spec. This was not a wet test and cold. My planned next steps: 1) Confirm valve setup / clearance 2) Check timing 3) Pull head - should I do something else prior to this? I have the complete shop manual - if I am going down a path of a complete rebuild, any other advice? Anything else that I should be concerned about with this loader and given it's hours? Hydro seems OK but I very reluctant to run it much. I will replace all filters / fluids and lube prior to use. Have been sourcing parts from Messick's Tractors. Thanks, Fred
