Engine blocks
Chrisjessc
Hey everyone I have a 2008 s160 that has the kubota v2607 in it.the engine threw a rod and broke a piece off the cylinder casting on #4 cylinder.i have been looking for a used v2607 but have gad no luck.does any know if the v2203 or v2003 use the same block.your input would help me out a lot.thanks
antfarmer2
If the 2203 will fit you can get a good running complet engine off ebay for under$1500 on ebay and save some work and money!!!
I think it's 60hp I'll have to double check
Is it turbo? that may be what gives you the few extra HP
I thought the V2203DI engines were able to get a turbo stuck on them, but don't hold me to that.
How bad is the damage where it threw the rod? can a shop machine it to install a new cylinder sleeve or is there a hole in the block?
