Finally found a 90 model 1840 that I could afford. Unit runs strong and is hydraulically pretty even on both sides. I've got two problems. I'm going to order a service manual this week but thought I'd ask you guys. All help is appreciated. 1. Gas gauge has all led's lit and I know the tank isn't full. Also can hear the relay behind the panel pull in about every 3-4 seconds. Several of the lights in the panel are dimly lit. 2. Got a small drip from the seal on the rear left tire drive chain plate. I assume there is some type of rubber or silicone seal. Do you take the tire off and unbolt the plate to correct? Thanks again! Skeet
