nobull1
- Joined
- Jan 4, 2007
- Messages
- 196
I was looking at the slack in the tilt cylinder eye and thought I would replace the bushing. Upon closer inspection I found the bosses for the bobtach were worn as well. I had been talking to the machine shop down the road and figured I would take it down when they were slow to get an opinion of what to do. We looked at it and their opinion was they could replace the eye bushing and line bore the bosses and make a couple of step bushings to repair the slack. While we were checking the bosses we also noticed that the lower part of the bobtach was sloppy on one side where it attaches to the arm. When they took it apart it was a mess from previous repair attempts. The hole the bushing went into was beat to death. So we decided to cut off the old bosses and make new step boss/bushing and weld in place. The thought was to make a boss that would take up the side to side slack and be a bushing as well to fix two problems. We purchased the seals that go behind the steel cups and found, after much discussion, that they could just wear and give more lateral slack down the road. The consensus was excavators do not use these seals and work fine. The other thing was there was no recess for the seal to fit in the boss. We decided that we would just leave them out and make a tight fit to the arms then make sure to grease on a regular bases. At present it is tight and works great, time will tell how long it works. The machine shop looks after me and charged me a third of the price of a new bobtach (which would have been needed for the average person)
A few people say there isn't enough material to line bore and install bushings in the bobtach tilt bosses. We bored and installed 1/8" step bushings and appear to be fine. Time will tell how long these repairs last, but they charge reasonable prices to me and we will just fix it if it doesn't last.
Anyone have opinions on this repair....good or bad?
