fordfairlane84
- Joined
- Apr 24, 2025
- Messages
- 4
I have a 2018 T630 with 1850 hours, I recently replaced the idler pulley, tensioner, and belt for the main drive from motor to hydraulic pump. The job seemed to go well, got the machine back running and used it a few days. The old pulley had nothing left in the bearing, and wore down the through bolt. So it was sloppy and needed replacing for some time but the machine was being run hard. There was however more chirping from the new belt and the engine began to shut down very hard, like if shutting the key down the motor slammed to a stop as if lots of friction. I checked multiple times for heat on any components and could not find source of rubbing.
After a long day of work, parked the machine, and in the morning, the starter made a terrible grinding noise. I immediately thought it was the starter, so I got the starter rebuilt. He said he replaced a bushing and the solenoid.
I installed the rebuilt starter and it fired up with some grinding. And same hard shutdown.
The machine only fired up two or three times with rebuilt starter and now it's back to heavy grinding and no start. The bendix hits about 1/2 the distance into the flywheel. It doesn't go all the way out. No start
I took the belt tension off and removed the belt from the motor and fired the machine with just the motor, and it fired right up and ran. The motor makes a high pitch metal on metal squeal, and the motor shuts down hard when shutting off.
I can spin the flywheel with a pry bar and it does have some audible friction as if something is binding.
I can also spin the hydraulic pump freely by hand.
Don't know if it's a starter, an engine, a hydraulic pump, or all of the above. It doesn't seem good.
I would so much appreciate your expertise and support!
