Bobcat t190 Glow Plug Problem
ECLC
I have a Bobcat t190 with a glowplug problem. They work perfect untill it gets around 60 degrees or lower outside they dont work witch is when you need them most. When i turn the key it will come up with the normal coundown from 19 seconds but then it stops counting down and the glowplug light blinks on the right pannel. The dealer has no idea what it could be. Thanks in advance for any help.
Have you checked the usual things?
Make sure the plugs are in good order, check the relay?
E
ECLC
Thanks for the help. I pulled off the cover for the fuse box and everything was corroded the rubber seal went bad and left in moisture. I cleaned and greased all the relays and fuses and now it works perfect. That saved me some money the dealer wanted me to bring it in so they could put it on the computer.
Glad you found the problem, the fues box always seems to attract moisture causing corrosion.
