Hello All, I'm hoping someone can help me with this problem we're having with our 2005 t190 527717819 machine. We started getting a code 11-06 when we were back dragging a parking lot. The 11-06 code is seat bar sensor short to ground. We changed the seat bar sensor and still have the problem only when the machine goes in reverse. You can lift anything you want, drive forward across the United States if you want but as soon as you go backwards it throws the 11-06 code. I checked the back up alarm wires and they look fine. I looked at the harness coming from the cab and it looks fine with no damage or wear. The back up alarm wires on the door are plugged in as they should be. The back up alarm has never worked and this problem just started. Is this a safety feature that prevents the machine from going backwards if the alarm or back up sensors are malfunctioning?
