can u explain charge pressure?Perhaps your implement pump is worn out. In addition to powering the hydraulics for lift and tilt. it provides charge pressure to the hydrostats. It's still good when the oil is cold and thick, but as it warms and thins, the worn pump shows.
If the lift and tilt functions also slow down when your drive starts to act up, I'd bet that's it.
There are other things it could be, tho. I'd check charge pressure cold and hot, first.
I've been looking at my manual. Charge pressure is the pressure of the oil that keeps the hydrostats full of oil at all times. According to my manual, this is only 45 psi for the M700. You can check it by istalling a gauge into the top of the filter housing that is attached to the hydrostatic pump. But now, since it's only 45 psi and your boom and bucket still work okay, I don't think that's your problem anyway.can u explain charge pressure?
Charge pressure is measured by removing the threaded plug on the upper hydraulic filter. Do you have the 720 manual to refer to?can u explain charge pressure?
wow... Im confused.... I think Ill get a manual..... then all the help im getting will make more sense...Charge pressure is measured by removing the threaded plug on the upper hydraulic filter. Do you have the 720 manual to refer to?
probably worn wear plates in the hydrostatic pump.....relatively easy repair there is a post or two here that explain it yell if you need help.....Jeffwow... Im confused.... I think Ill get a manual..... then all the help im getting will make more sense...
Lift the cab, on top of the pump there should be a square block with 3 hoses on the left, remove the middle one and fitting, there should be a filter behind here. Clean or replace it, it should clear up your drive issues.probably worn wear plates in the hydrostatic pump.....relatively easy repair there is a post or two here that explain it yell if you need help.....Jeff
I Gave up and took it to the dealer for an estimate...thanx for the help we'll see what they say...Lift the cab, on top of the pump there should be a square block with 3 hoses on the left, remove the middle one and fitting, there should be a filter behind here. Clean or replace it, it should clear up your drive issues.
Hopefully your machine has this suction line filter fitted! Its a known issue.
Let us know what they have to say.I Gave up and took it to the dealer for an estimate...thanx for the help we'll see what they say...
