Hi guys, I'm trying to have my lift arm cylinder on the right side rebuilt. Here's the problem, I can't remove the cylinder from the loader. My repair book says, with the arms down, cab raised, release cylinder pins from both ends, which i did. Remove both hydraulic lines from the cylinder body, which i did. Then it says remove the cylinder from the loader straight forward, which i can't. Tha durn lift arm is in the way. There's very little room for lateral movement in there and its very heavy. I tried jacking the lift arm assembly at the bucket with a hydraulic jack to get more room to remove the cylinder but the entire machine lifts off the ground. I've been at this all day with no luck. No room to remove it at the back door either. Can someone help, please. thanks kerry
