OK, lemme offer some half-baked thoughts here, as I'm still a novice at Bobcats. First, I think the 900 series machines are fairly old, so probably not computer controlled, but we need to sort that out first. What do the upper left and upper right panels in the cab look like? Is there a module with about 5 green LEDs just behind the operator's right elbow? That will get us started with understanding how your machine is configured. --- The valves on the arms and bucket are "locked" by solenoids until the machine decides it's ready to work. If neither arms or bucket will move, then the solenoids are not releasing, most likely because the safety control mechanism hasn't told them to release. So somehow, the control mechanism probably thinks it's not OK to operate the machine. There is likely a seat switch and a lap bar switch. If either are not "engaging", then the control mechanism won't let the machine do anything. That would be a place to start looking to see if either of those may be preventing an unlock. BTW, since the arms won't move, sounds like the "parking brake" will be engaged also, so the machine probably won't move more than a few inches. --- So with some answers to the above, some of us can offer more advice. BTW, the hydraulic release Tom... mentioned is adjacent to the seat on the right hand side, about an inch to the right of the seat edge, right in the middle (front-to-back). Or maybe the knob got lost and it's just a 1/4" threaded stud sticking up an inch or so. If you pull up an inch or so and rotate it to the right, the hyd pressure will be released and the arms will come down. Be really careful to be out of the way, since there's no getting the arms back up. Also, if you will need to drag this machine anywhere, you may want to stop the arms before the bucket drags the ground. Good luck!
---Bobbie-G
