Hello,
i went to start it and it took about 20 key turns to start , it was hitting just wouldnt start
got it started and it ran for a couple minutes the died , i then blew air back through the line before it reaches the hand pump and it went through the tank fine i could hear it , it would also pump fuel out the hand pump when you pumped it , so i then took the filter off it was almost complety empty so i figured the fuel pump went out , i orderd a fuel pump off ebay for 70.00 should be here in a few days ,, i hope this was the problem after all a fuel pump going out , any thing i need to know on a fuel pump change out ? just remove the old install the new pump ??
Thanks for all of the replies
Jess
