SaltyOlive
- Joined
- Dec 7, 2019
- Messages
- 11
Help
I have a old 743 bobcat that has a spool valve assembly mounted on the right side of the inside frame rail.
Every tube that goes into the valve are metal except for two rubber hoses....
One is mounted an the top and the other the bottom....
I’ve tried everything I can think, short of pulling the motor to get access to that lower hose....
The lower hose formed a pin hole that’s spraying.
I Recently removed all the metal tubes except for the last one that will not budge because it feeds behind the engine.
If anyone has ever had this issue and knows how to get this hose off aside from removing the engine, please help
Thank You,
Steve
Thank You,
Steve
