peebeeaitch
- Joined
- Dec 3, 2012
- Messages
- 115
I bought a 630 for a project and this is the chronology of its reclamation.
22 Dec 2012
Cleaning (a colleague lent me a "hotsy"):
Moving the machine from where the towing company left it - always have a good friend with a car "with a big engine and really sh*tty gas mileage" (RoboCop) to help. Also, two pallet jacks can lift 3 Bobcat 630's (according to the manufacturer of the pallet jacks and the Bobcat):
Hillbilly owner (me). Strong car (belonging to good friend):
And finally:
23 Dec 2012
Spent the morning opening various covers. Checked the distributor for water and found plenty from the "hotsy". I was told when I bought the machine that it had worked but the left stick stopped sending the force to the left wheels. The force was working on the right though. Obviously, starting the engine was the key to determining if the force could be moved to the left. Armed with a cheap set of wrenches and a can of QuickStart I managed to get a burp out of the engine. The fuel tank has been replaced by a Jerry Can with custom brazed connection at the bottom leading to a primable fuel filter. No fuel out of the fuel filter outlet and I rushed off to get a funnel to fill the tank to be able to prime the bowl. A bit of propane torch on the funnel and I managed to bend the end to fit in the "tank". I also was reminded that plastic that is bendable and collapses tends to hurt fingers that are introduced to the opening to "unbend" kink. Filled the tank, primed the pump and introduced the starting fluid and SHE FIRED UP!!!
Note to self: When the rest of the family is watching the festivities from a SEPARATE room, looking through a glass pane in the door, furious gesticulations and pointing are generally not signs of awe and wonderment at one's ability in getting dead mechanical machinery alive, they are more likely signs of catastrophic failure of hydraulic lines one cannot see:
(the broken line is, quite predicatably, hidden below the hinge pin on the right support arm).
I shut the engine off. After thinking about it for a while (and cleaning the mess), I decided that the oil that had leaked was probably in need of replacing anyway, and there was hopefully enough left to lift the arms so that I could get to the hose connector to replace the lines:
This is the tilt cylinder with a seriously frayed line. I can only imagine what the other one leading into the arm looks like.
Also, I noticed earlier this evening that the right support arm is kinked (see photo above). This is bad news (and explains why the ROPS on the right is closer to the arm than on the left). I hope I can get the back hinge pin out to replace it - the previous owners did not believe in grease, hence the sloppiness in all hydraulic motions.
To do:
* buy tools to remove lines
* replace lines
* get engine to fire without Quick Start
* replace starter solenoid
* dump snow
22 Dec 2012
And finally:
23 Dec 2012
To do:
* replace lines
* dump snow
