Bobcat 463 Grease Fitting Locations
BobcatPaul
The year of the Bobcat 463 is 2002. Assuming there are grease fittings for the steering shaft pivot bearings, where are they located? I have even lifted the cab and still cannot find them. Thanks, Paul
Hotrod1830
I would be suprised if it has them. My 553 didnt have one. After taking the shaft apart to clean all the rust out of it, I added one.
Hotrod1830
Edit....... The outer bearing's may have a grease fitting in the wheel area. I was refering to the bushings that seperate the 2 steering lever shafts.
SkidRoe
My 440b has a couple of holes in this location that you squirt oil in from time to time. Pain in the butt, you have to lift the cab to do it, so it does not get done that often.
HTH - SR
