Bobcat 337D excavator all controls stop working.
124NUMB
Hi all. After about an hour of operating my 337D all controls stop working and machine will travel very slow. Only error code that shows up is 06-13. I have installed a new speed sensor, new starter motor, replaced all oils and installed new filters and new coolant. Any ideas on what might be the issue.
Well, it seems like you already have marked many of the potential issues with your 337D! That’s a win man!.
To my understand, machine's hydraulic system or hydraulic control unit might usually the source of the error code 06-13. It may be worthwhile to check the hydraulic fluid level and pressure after replacing the speed sensor and starting motor. You should also examine the hydraulic hoses and connections for damage or leaks. If everything appears to be in order there, you might want to think about having a qualified expert examine the device more closely in order to identify and fix the problem.
I hope this helps!
Well, it seems like you already have marked many of the potential issues with your 337D! That's a win man!.
I hope this helps!
Thanks for the reply branden.
I have only used the machine for a short time after doing all the work and it didnt play up.
But due to on going rain over here i havnt had a chance to really give it a few hours non stop work to see if issue is solved.
So fingers crossed.
